Quick VB6 Split String help
1 Mar 2006
hi Guys
string is:
":USERNAME![email protected] PRIVMSG #Channel :Hello World"
i need to split the string to show
USERNAME:Hello World
im currently using the below
Dim Msg As String
Msg = Split(Data, " PRIVMSG " & Channel & " :")(1)
which returns
USERNAME:
and no hello world what am i doing wrong here? ive done this a million times in the past :confused:
I tested the code you have there and it returned 'Hello world' - not username, as you're setting msg = to the second element of the array.
Anway, here's something which should hopefully work for you. I've tested it using ASP/VBScript, but should be simple enough to translate to VB6.
Code:
	data = ":[email protected] PRIVMSG #Channel :Hello World"
	values = split(data, ":")
	label = split(values(1), "!")(0)
	response.write(label & ":" & values(ubound(values)))
thanks for that
the string is coming through a socket from a IRC server
i thought about
Code:
Dim Msg As String
Dim Msg2 As string
Dim msg3 as string
Msg = Split(Data, " PRIVMSG " & Channel & " :")(1) ‘ which gives you “USERNAME”
Msg2 = Split(Data, " PRIVMSG " & Channel & " :")(2) ‘ which should give you “:hello world”
Then concentrate msg and msg2 into msg3 dimension? To get USERNAME:hello world
Text1.text = (msg3) ‘ show concentrated string in textbox
Or is that just rubbish
Assuming the data is the same as your OP...
Code:
... will give you 'USERNAME![email protected]'
Code:
... will give you 'Hello World'
.: You'd get 'USERNAME![email protected]:Hello World'. Is this what you want?
Try the code I posted before, it gives exactly the result you wanted in your OP.
