Quiet ATX Case for multi GPU rig
20 Nov 2010
Hi,
I'm looking for a quiet enclosed case for a multi GPU rig that contains enough space for 2 vega 64's.
I only have a single SSD so don't need loads of storage options in that sense...just enough space for 2 vega 64s. Will i be able to fit a second GPu in the second slot? Will it be too close to the other GPU for adequate cooling?
If it has space for 3 vegas(using all 3 slots, including the lowest), that would be extra great too.
Please help!!
Thanks
Just to clarify, this is not for an SLI setup.
I just need two asus strix vega 64's slotted into the motherboard in a case that is quiet but has great cooling.
Please help!
there's a few good quiet cases around
you after anything else in particular? space for water cooling? got a price in mind?
if you don't mind the price, the Be Quiet 700 is a pretty solid case for you
https://www.overclockers.co.uk/be-q...ower-case-black-tempered-glass-ca-124-bq.html
comes with more than enough space for what you'll need, sound dampening where you need it, and space for expansion if you go into liquid cooling down the road
Thanks for the reply! I definitely don't want a see through window....rather it be plain and simple!
Thanks for the recommendation..i'm assuming there's a windowless version out there somewhere too.
looking at my motherboard, do you think i'll be able to get 3 GPU's in the pci slots, including the last one? Like i said, i don't care about SLI so would like to utilise the last x1 slot, but judging by the case, i'm not sure it would fit without touching the bottom panel?
Thanks again.
