*Looks at site name*
*Looks at Akasa advert on the site*
I'd rather wait for a site like SPCR to test them against other fans properly if I'm honest.
The Sharkoons are good ain't theyI have Sharkoon SE 2000 running at 7v by fan control and they are brilliant
Personally I would look for the Nexus 120mm fans, they're based on Yate Loons but running at 9-10v and 1000rpm. They're quieter without compromising too much on airflow, only about £1 more, come with rubber mounts and the black/white ones look a lot better.
What rpm does sharkoon 120mm 2000 series fan rotate at using 7v btw?
Got two of these today, and they're ace
How did you work that out!if it scales linearly then it will be about 1167 RPM.
I've got the SL's, they have both a 3pin motherboard header connection aswell as 4 pin molex.
The SLs can be had for £4 including VAT if you know where to look.
