Quiet fans to replace Corsair Hydro Series iCUE H100i fans?
3 Jul 2004
I have a Corsair Hydro Series iCUE H100i RGB ELITE Performance Liquid CPU Cooler 240mm, which came with 2 x 120 mm fans. Recently I have noticed that the fans start to get noisy above 1100 RPM. Can anyone recommend some replacement (non-RGB) fans that will be quieter (silentish) at this speed and above?
Many thanks
The Corsair SP fans are decent too, designed for static pressure so they'll work well on a radiator, I have two of the 140mm SP RGB Elites on mine and a further three as case fans. I tried the AF fans but hated them, they were ridiculously noisy and caused loads of vibration. The airflow was at least decent but not worth the noise.
I should have mentioned, I don't want RGB, and all the Corsair fans sold by overclockers seem to be RGB. My Corsair cooler came with 2 Corsair AF Elites (no RGB), which, as you say, are noisy over about 1100 RPM.
Based on the great advice in this thread, I got a couple of Artic P12 PWM Max, and they are great - much quieter than the Corsair fans that came with the cooler.
Artic P12 PWM Max or Noctua NF-P12 Redux 1700rpm if you don't mind spending a little more. Artic in my experience are slightly noisier than Noctua, as mentioned above you can't really beat the price/performance of the Artic.
