I am using my 580 Watt Tagan at the moment, and have never had any issues with it, however it does produce a lot more noise than I would like. I used a Hiper before and this was almost silent under normal conditions, but well it was a hiper so it went wrong.
I used an Enermax Galaxy 850W for a while which is a fantasic PSU, but is definately not a quiet one and covered over my top exhaust when I would normally fit a fan.
So now I'm looking for a modular PSU which is almost silent but has the power on the 12V rails to happily run my 8800GTX and the rest of my system. Been looking around the 700W range, but the GTX needs atleast 29A on a rail I believe. Not worried at all about LED spent the last year getting rid of any fans with them.
I've been looking at the following:
Silverstone SST-OP750
Seasonic M12-700
And briefly at Coolermaster Real Power M700 and the Tagan ixeye 800W
I've got around £100 to spend, but would prefer to keep it below that if possible as looking for a new CPU cooler as this artic freezer 7 is producing too much noise too. (Though i've read they are meant to be quiet so there might be something wrong there.) Nothing is overclocked and if I ever do get my 680i board back from EVGA I might get around to it, but noise is more important than overclocking at the moment. Looking at thermalright 120 Ultra - good idea?
So any suggestions on the PSU's and tell me if I'm looking at totally the wrong ones, up till the last 2 yrs I'll always gone for the cheap and cheerful PSUs.
And any suggestions as to the cooling for my cpu aswell would be great.
Thanks
Seasonic M12-700
Thanks
If you are a bit "nngh" about it, then get the 620w version but it's £30 more. Either the 520w or 620w PSU is VERY silent, and regarded as two of the best power supplies around.
