Quiet Quad-Core Build
17 Apr 2006
I started a thread about getting a new build the other day but I've now done more research / digging and think I've refined what I'm after somewhat!
So, my budget is between £500 and £700 (cheaper = better).
What I am after:
  • Quad core (a must for my development work)
  • Fair graphics card (TF2 at 1650x1080 is as taxing as it gets) - but not ATI
  • Support for dual monitors
  • Something _quiet_
  • Parts that are happily compatible with Ubuntu and Windows 7
  • 500gb or less storage
I have done several builds in the past and am happy replacing the fan on the graphics card if that's still a standard job in quiet builds.
I already have: case, keyboard, mouse, monitors, speakers, DVD writer and a wireless card
Any suggestions? :)
wont let me onto shop site atm, but Id recomend something around a i5 750 CPU, gigabyte UD2 mobo, NVidia 260 gfx
Edit: In now, done this, comes to top end of budget, mainly because Ive included premium case to match your request for quietness as best as possible
re-edit: you may also want to replace the retail cooler for improved acoustics, but atm info on 1156 coolers is scarce, I suspect theyll just release new backplates to convert most the existing coolers over, but not many have done so yet, afaik
I've got a pretty nice Akasa case that is really quiet so I'll probably keep that and save £113 :-D
Am thinking of spending the saved money on going to 8gb (4x2gb sticks). Is the stock fan that comes with the Intel CPU quiet? My last two builds needed ~£40 spent on a different CPU fan
The one with the M is MicroATX, so small form factor
Do you really need 8 gig of RAM, most people dont, re the CPU, I think for stock speeds the retail cooler is fine, but if you OC the additional load causes it to make a bit of a racket, as I say Im sure theyll do brackets for old coolers, so if youve got your old one you should be able to use that when the bracket gets released, just use the retail in the meantime
I'll probably not OC initially but may do in the future... guess I can try out the stock fan and replace if needed :)
Quite a few of the applications I use are memory hungry. Again, I could go for 4gb and see what it feels like and what the memory consumption is like.
Is going micro ATX a good idea? Or would I be better going for normal ATX? My case takes either if I remember correctly - and is still sold! http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-AK&groupid=701&catid=7&subcat=507 :D
Just noticed that the gfx card has only one DVI output (and one VGA). Had a look around and can't find any that have two DVI and are still quiet... any ideas? (can survive with VGA+DVI but would rather two DVI)
ahhh you using ubuntu on the new rig?
Fair enough :) was gonna say bang for buck wise ati are good but you have a sensible reason for avoiding them :)
Ubuntu and Windows 7... Faffing about with Wine and getting games/Office running on Ubuntu just isn't worth the hassle when dual-booting is easy :)
Top end of your budget!
PLus you should get free postage since youve been here 3 years and over 100 posts so it should be £697
As you mentioned you'll be using the PC for development work ive chosen the i7 over the i5, plus 1366 gives you the chance to upgrade to i9 and 6cores down the line.
Edit: the vipers out of stock atm!
Hadn't realised this, thanks!
Realistically, I'm unlikely to upgrade the CPU for another 2-3 years (how long it normally takes me to get around to it). Will we still have Intel chucking out 1366 chips or will I be forced to get a new mobo anyway? :)
Also, what makes the i7 more suitable for development over the i5?
Well in 2-3 years time youll prob be able to pick upa i7 975ED cheap if you wanted to upgrade or drop in a 6 core I7 processor
i5 750 4 cores 4 threads
i7 920 4 cores 8 threads
i7's 1366's more suited to number crunching, video encoding and general heavy work
Edit: added 1366 in bold for derranged persons benefit below!
If i was you, i would go with the i5 route, and get a gtx 260 and not a gtx 275, all you got to do is overclock the gtx 260 and it will become faster than gtx 275, pushing towards gtx 280 lines. I know you don't want ati but there 4890 is probs the best card you can get for the price right now
860's more expensive plus it utilises 1156 which allows for dual channel ddr3 rather than tri-channel ddr3 on the 1366.Tri channel has greater memory bandwidth.
Also 920 clocks like a mother and the 860 looks like itll match the 920.. but its more expensive!
Anyway this is my preference for the useage hes talking about
For the OP about free postage
http://forums.overclockers.co.uk/sh...&posted=1&utm_source=forums&utm_medium=banner
what? the 750 beats both the 920 and 950, do your research
What ARE you talking about?
750 may beat the 920 at stock for gaming but not the 950 and besides if you read the Original Post its not to be used for gaming but for development work where the i7 1366's will be of MORE benefit for his need
