Quiet/ Silent cooling advice
15 Dec 2007
Hi,
I have issues with the noise from my pc, could any one suggest replacement cooling solutions that would fit.
I have a Asus P5B Delxue mobo, a E6600 cpu, a HD2900 Pro gfx card (really noisy) and a Type R power supply. I have a Coolermaster wave master case. It has 2 x nexus 80mm cooling fans in the front and 1 on the back.
Any advice would be appreciated,
Thanks
Hi , at the moment I have 5 x 120mm fans in my case ,I will be adding 2 more on the side panel (work in progress). I have them connected to a fan controller,Its not rocket science to fit either.
http://www.overclockers.co.uk/showproduct.php?prodid=BB-002-ZA&groupid=701&catid=57&subcat=189
you also may need a fan extension cable ( to reach the rear fan) depending on the size of your case
You can connect the nexus fans & cpu fan to this and reduce the speed/volts to 5v, it greatly reduces the noise of 5 fans and is barely noticable,don`t know about the GFX card though,If you connect to the cpu fan ,check temps with coretemp
good luck
tommysdad
You can you something like RivaTuner to dynamicaly adjust the graphics card fan speed depending on the temp of the card, speedfan can be used on the cpu and chasis fans to control their speed based on temps..
Thanks for the replys.
I was thinking of some thing along the lines af new heat sinks. I am not sure what will actually fit, and if I could cool passivly.
would fitting that void my warranty?
Technically yes (except with EVGA if I remember correctly).
would it fit along with an aftermarket cpu cooler?
Most venders release compatibility information on their website. Try the website of the people who make the heatsink you're looking at. Graphics card sinks shouldn't really interfere with the n/b or cpu sink unless your board design is a bit weird. Again however, check the sink manufacturer's website.
Water cool the 2900.
Both of mine are. They idle at 40 instead of 60 and max out around 55 instead of 90. Oh and now they're overclocked to 900/1050!
80mm fans are always noisy. You're better off with a case that supports 120mm, but I know thats not always practical.
I've heard great things about that aftermarket cooler for the 2900, so go for it. Just make sure you use decent thermal paste like Artic Silver 5.
Thanks for the replys and pics (looks ace)
I decided to take the plunge and ordered:
-Thermalright Ultra-120 Extreme CPU Cooler (Socket AM2/LGA775)
-Noctua NF-S12 1200RPM 120mm Silent Case Fan - 3 Pin
-Thermalright HR-03/R600 (HD2900XT) VGA Cooler
-Arctic Cooling MX-2 Thermal Compound
Now I just have to wait for delivery :)
My stuff arrived today, the cpu cooler isnt going to fit in my case, the ends of the heat pipe are stopping it fitting thought I have not attempeded to fit it, can it be returned and exchanged for a different cooler, which one would you suggest?
Thanks
Zalman CNPS9700-LED or Tuniq Tower 120 - I would check size proportions vs. the 120 Extreme however to make sure that whichever one you pick will fit, and also fit your motherboard and not hit capacitors. I have the Zalman and it's ultra quiet and a great cooler, plus it comes with a Zalman Fan Mate so you can adjust the speed of the fan outside the case for when you want quiet / loud moments.
The Thermalright HR-03/R600 only seems to have reduced my temps by about 5 degrees on idle. Is this normal? It has a fan attached.
EDIT*
It may have only reduced the idle temps by a few degrees, but they only rise a few degrees when under load too.
last 2 days of playing Guitar Hero 3 1680x1050 high settings and same on TF2 core temp(rivatuner) doesnt rise above 55(old idle temp) degrees.
The voltage regulator temp was getting a bit high, in to the 80s but after moving my hard drive to give better air flow under the card it sits nicely at 60 degrees under load.
This seems to be an excellent cooler cooler.
