quiet/silent power supply needed
7 Jul 2008
Newcastle upon Tyne
I bought a Cooler Master for me old rig which is not that old but the fans runs all the time and is noisy so looking for a replacement
I would like suggestions as to what power to go for and a recommendation as to which supply however I seem to see the name Super Flower Leadex mentioned.
The rig, so you have an idea what its powering:
Gigabyte X99 Micro Atx in a Corsair 240 cube case
Intel i7-5829 clocked at 4000mhz
32 GB DDR4 ram 4x8 modules
Gforce 960 mildly clocked
3 x ssd amd 1 x HHD
3 x 120mm fans
No CD/DVD or floppy
about 3 USB devices
Superflower do make good PSUs. The Leadex is a fully modular PSU, but the modular connectors are backlit as per the product picture:
https://www.overclockers.co.uk/supe...lus-gold-power-supply-gunmetal-ca-048-sf.html
If you don't mind the LEDs (it puts some people off), then go for it, as it's a great PSU. The EVGA Supernova G2 series are basically the Leadex PSUs without the LEDs.
You only need a good 550W PSU for that setup, so the Leadex 550W would be a good choice. The Leadex also has an Eco-mode switch which means that the fan will only come on once the PSU has reached a certain temperature.
If a non-modular PSU would be OK, then the Antec TruePower Classic would be a good choice:
https://www.overclockers.co.uk/antec-truepower-classic-550w-80-plus-gold-power-supply-ca-202-an.html
Silverstone do two fanless PSUs at 460W and 520W. I have the Silverpower version of the 460W and it's wonderful. If you need more power, the Leadex 850W stops the fan at low power consumption.
There are some semi-passive power supplies available, only switch on the fan when above a certain load.
