Quietest 7600GT?
18 Oct 2002
Bristol
Can anyone recommend me a good 7600GT card - not too fussed about £10 either way, I just want the one with the quietest heatsink/fan combo that still works. Maybe rephrase the question to simply, which is the quietest 7600GT available?
If you can find a passively cooled one, that should do you.
The Asus EN7600GT Silent has rotating heatsink fins that are on top of the card & allow it to fit in various installations including small HTPC.
There is also the Gainward Bliss GeForce 7600GT Golden Sample SilentFX Passive card.
The Gigabyte 7600GT, GV-NX76T256D-RH graphics card is also passively cooled.
There may be others.
Thanks, I didn't realise any 7600GTs were passively cooled... do you think passive cooling is up to the job on these cards?
the heatsinks are up to the job but they do require some sort of airflow over them from case fans etc. I wouldnt overclock them though unless you have v good airflow over it.
I'm a bit wary of passive designs on cards of that calibre, especially as the 7600GS passive cards run fairly hot, a higher clocked GT can only be hotter, although some of the passive designs can be good enough. If you're upto swapping the heatsink yourself, an alternative might be to get a standard 7600GT and put a Zalman VGA cooler on it.
