- 26 Jan 2006
For a socket 939 would be ?
But it's gotta be good enough to let me Overclock, any ideas?
urm depends on your interpretation of loud? i bought a freezer 64 pro and thought it was crazy silent, currently running a TT big typhoon with a 120mm panaflo m1A think they are rated at about 36db and i still wouldn't class it as loud? yes it's audible but hardly loudErNciLator said:Freezer pro is quite loud irrc, had it before, does water cooling have many/any fans?
Depends on the pump. A Laing DDC will be quieter than your hard drives...Chris Beard said:Watercooling has a pump which can be noisy. A silent solution has to be a passive cooling solution. You can dump your PC in baby oil for instance?
Best bet is probably the sonic tower, just as wizardmaxx suggests. However, you will NEED good case cooling to make quiet air cooling work for an overclock.
//edit: should really proof read my posts...
I have to agree with him, dont know what components you guys use in your pc but by far the arctic cooler is the loudest thing in my pc, soo much so that i let speedfan run it at 50% speed until it heats up then make it run faster.ErNciLator said:Freezer pro is quite loud irrc, had it before, does water cooling have many/any fans?
i was amazed at how quiet it was, if you heard my system you would probably keel over lol, i'm running a panaflo m1A at 12v and two of the 125cfm ys-tech's at 7v and i wouldn't class my system as loud? as i stated earlier it's audible but by no means an annoyance, the way i see it is that i never really hear it as i'm either gaming with headphones on or listening to music through speakers! so it's only those around me who i annoy with the fans
Chris Beard said:Ahh, but not if you dump your hard drives in baby oil!
Originally Posted by samcat
Yes, because then they will stop working....
I noticed... but I guess I didn't make it clear enoughChris Beard said:True. Was wondering when someone would notice that...
