Hey guys,
Right, I have a predicament. Please bear with me while I get it all down lol
At the moment:
Which Cloning (if cloning is even the right choice) software do I use? Would I be able to convert my friend's USB hard drive to a temporary boot drive to enable restoring of the 'clone images' as it were? If thats possible, which means do you recommend?
Look forward to hearing your wise advice
At the moment:
- Two brand new 150GB Raptors have just arrived, to replace my existing raptors detailed below
- I currently have 4 36GB Raptors in a single RAID 0 array (using SiRAID in my DFI SLI-DR)
- This 4-raptor array currently has 80GB of data (across 2 partitions) I need to keep (including a windows install I need to preserve completely intact - I don't want to format again! I have everything just the way I want it)
- I want these 2 new raptors to be in a RAID 0 array, using the same onboard RAID controller as what I have at the moment.
- I have borrowed my mate's external USB hard drive which has ample space for the transfer, but he has some important files on it which cannot be taken off it. I'm 99.9% sure I can boot off this hard drive if I prioritise it in BIOS (it recognised my Ipod, so I doubt it'll have difficulty with this)
