QX6850 'Kentsfield'
19 Jan 2006
Harefield
anyone know if the above CPU will be ok with the Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit (anyone know if this will oc to 1333MHz) or am i taking to much of a chance ?
could anyone other wise recommend any ram to suit. building this beast in the morning.
The RAM speed when running sync with FSB should be DDR2 667 which is what your RAM is rated at, but your kit is very well known for achieving well beyond DDR2 1000 so it's perfectly suitable for that CPU.
AlexWolf said:
I thought they were only selling them after July the 22nd :o
I think its selling for $999 on the prcie drop table thing..
Lucky :P
as far as i know they still are - got it from a friend of a friend (if u know what i mean)
Didn't get me nine though you shabby [edited for self appointed forum POLICE] :D
AND sign in MSN and block everyone else muppet.
CS||nuTs said:
Being as he is one of my best mates im sure he wont mind...That ok with you?
'Tis fair enough that he's a friend of yours, but you really don't need to use that language on here. Spie would imply that it's a family forum (?!) so please mind your language. All you have to do is press the "edit" button and star it out.
running at default volts atm @ upto 800MHz (t2 i think) 5,5,5,15
well good news in away new pc up and running for now with the default cooler the cooler we think was to much pressure on the slightly bent pin so not so great, going to try and rma the mobo; hopefuly it should be replaced in the next few days.
this is all set to default not tweeking at all going 2 wait for the better cool and may be some better ram.
ran 3dmk06 and cpuz
man_from_uncle said:
Family? I don't think this is even a multi-gender forum.
Which is fine by me.
Youre absolutely right in that assumption. But I didn't want to get called up by the self-appointed police of the language fascists on here. :)
nice cpu there, a quad core G0 stepping
now OvErCloCk that pleazzz. :D
you should get to something like 3.6 with low volts and 3.9-4.0 if u are lucky max on air.
whats G0 stepping :confused:
if i wanted 2 run it at 3.6 ghz would i need better ram ? and if so what would you recommended
