Caporegime
- 18 Sep 2009
- Dormanstown.
Well, I did say long gaming stints..
Well, I did say proper gaming stints..
I'd hope I have good air flow, I have a Xigamatek Elysium
If you don't think it'll change, that's fine, like I say, I don't need proof.
Don't know, I've got a sapphire Tri-X now as of last Thursday.
If I blasted the fan up I could keep it cool tbh, but at 50% no chance.
85c after half an hour? That's pretty damn hot.
That would go up after a constant 6 hours of gaming![]()
I don't need you to prove anything.
Half an hour isn't much at all though.
I mean PROPER gaming sessions, 6 hours of gaming, the heat it pumps out warms up the room, warms up everything as suddenly your PC's in taking warmer air etc etc.
50% wasn't enough.
Totally agree with your point regarding heat progressively getting worse. Though to be honest this is the same with every type of high end GPU.
I have a small room to game in and I can keep heat under control for brief 30min - 1hr runs on my R9 290X CF system. I have a Corsair H540 high airflow case and temps are great but it expels all that hot air into the room. Once the hot air builds up in the room the PC is using hot air to try to keep cool. A proper 2+ hour gaming session with CF 290s (or the SLI GTX780s I also had) becomes unbearable even with a window open in winter.
I recently did 2+ hours in Assetto Corsa which gives 80%+ scaling in CF. I eventually started noticing artefacts at stock speeds and quit the game, the VRM temperatures were 115c.
Single GPU is fine here, but I keep being a sucker and going SLI/CF for the power. Then I end up removing the extra GPU due to heat problems. I have an R9 290 sitting behind me with no intentions of ever putting it back in. I can keep it as a spare for the next few years.
As Homer Simpson famously said, "In this house we obey the laws of thermodynamics".![]()
That's far from a conventional fan set up, are those 3 intake?
Wow. I thought i had a hot room. That's bizarre mate. I find my vrms are 10-14c cooler than the core temps, even under heavy load for longer periods!!
My situation demands quietness over cooling efficiency. I have a baby sleeping across the hall and the only time I get to game is when he is asleep.
For quietness I am using a Arctic hybrid GPU cooling set-up for my top card and a R9 290 Tri-X for the bottom card. Even with an Alpenphon Peter VRM heatsink the VRMs are hotter than a stock cooled R9 290X. In single GPU mode the VRMs will happily sit at mid-high 80s even at ~100mv and 1170/1500.
In multi GPU the heat from the bottom card will eventually (2+ hours of gaming) push the VRMs up by ~20c into the hundreds.
Stock cooled R9 290s are not an option as they are far too loud IMHO, and more importantly in the babies opinion
Having said that I had 2x GTX680s with stock coolers and they caused the exact same eventual overheating problems with long gaming sessions. I really should stop trying multi GPU.
Yeah that's fair enough. Used a few Acceleros myself and they're deadly silent. As you find out though, the achilles heel is the vrm temps. Ok if you're not in a sweatbox mind you. The stock cooler is louder, but it does do a good (ish) job on the vrms as the fan sits right on top of them.
With my Accelero Hybrid I got the VRMs to a similar level as an R9 290 Tri-X. Though even the Tri-X is around 5-10c higher than a stock R9 290/X for VRM temperature.
Having said that I do feel, from testing, that stock R9 290/X coolers are inefficient and barely adequate for the job.
