- 13 Nov 2010
Hopefully upgrading to a R9 280X, but doubt my 450W PSU is going to quite cut it, (also don't think it has enough power connections as I read 280X requires 1x 8 pin and 1x 6 pin connectors) after using power calculator minimum requirements showing as 457w and 507w Max.
looking at http://www.overclockers.co.uk/showproduct.php?prodid=CA-153-CS
would that be ok or any other recommendations somewhere between £60-£90 area
Asus M5A97 Pro Mobo
AMD black edition FX4100 quad core 3.6ghz OC'd to 4.2ghz
1 x HDD
1 x DVDR
8gb RAM
4 x 120mm fans 1x 200mm fan
(will add an SSD for OS eventually)
and ofc the 280X
Asus M5A97 Pro Mobo
1 x HDD
1 x DVDR
8gb RAM
and ofc the 280X
. I'm running my R9 280X off a 600W gold rated PSU (Cooler Master Silent Pro Gold).
