The EK full cover 290 Acetal+Nickel blocks also fit some 390's, but it seems to depend on the manufacturer. Have a look at their compatibility list or use their config tool and you might be OK.
the powercolour 390x fits the standard 290x block the msi, asus & sapphire however don't and ek say they not making any. as said above go to the ek configurator to be certain
Only some 290 full blocks which might work on certain vendors but nothing specifically for the 390 I think.
I had to do it this way with my MSI 390's. Standard Thermosphere GPU blocks, then went to work on the coolers to make them fit on the cards to cool the chips and the VRM's
