its not crashing completely but has lines and glitches flying all over the place
i have sent the card back to ocuk.
managed to do some digging in my crash files from playerunknowns battleground.
"Unreal Engine is exiting due to D3D device being lost."
appears on every single crash. surely can only be a gpu issue?
Temps never went above 70 degrees.So a clean Windows install, newest drivers and a brand new PSU and multiple games effected and you still getting crashes. Was your card factory overclock? It could be overheating or the overclock may have not been stable. If you still had the card I would have recommended underclocking to see if that improves stability, also monitoring temps would be useful as well.
I've no idea which bios is which - with the LED on button turned on the card was dumping constantly. When switched to bios with LED off then the card would also dump but last maybe 5mins into a game as opposed to 2minutes.The second BIOS allows a higher power limit of 300W and higher target temp before throttling
Good luck with the RMA
Has been confirmed as faulty by ocuk.
Replacement card is on its way to me.
Fantastic support as always from the guys.
