- 18 Mar 2011
- East London.
Im finally about to buy my WC parts, before i do just a quick Q regards the the title.
The rads im after allow me to mount both 140 or 120 mm fans. I want to know what is the best solution for me. I will be using a 140.3 and a 140.2 rad to cool an overclocked 2600k and overclocked GTX580. (Have i got enough rad surface?)
Apparently 140mm fans are 'not all that' compared to 120 mm fans, static pressure etc, im not sure so hence my asking here.
The rads are 10 fins per inch, i understand this has some significance as to the type of fans that should be used? Could someone explain please so i can learn.
Also, with the fans do I use them to pull the heat from the rad out (fan on top) or push the heat out (fan on bottom) or both?
Can someone recommend some fans (both sizes) for the above scenario. Fans which move a good amount of air and are quiet would be nice. I am aware there is a compromise to be made somewhere
If it helps, the case will be the Fractal Design Arc Midi, modified for the 140.3
There are two fan spaces (120/140mm) that are available to use as intake or exhaust in addition to the fans for the rads.
If you need more info, please ask away.
