Rad help please!
11 Apr 2012
These are all components I have, i'm building a list for my next purchase so I can get the rads and fans off the to get list so I can start the plumbing.
Loop #1
res, pump, 120x2 rad, CPU, 120mm rad, motherboard block, RAM block, res
Loop #2
res, pump, 200mm phobya rad, GPU1, GPU2, res
_______________
Loop#1: Will this loop need more RAD surface area? I could lose the 120mm and add a 2x120mm with only a little modding no prob
loop#2: Will adding only another 120mm rad be enough?
