in rad water time max = maximum heat transfer out of rad...
compared to in block water time min = max heat trans out of cpu
so basically in block u want max flow in rad u want max time
regardless of the individual component
fast water in cooling block = max heat exchhange
slow water in rad = max heat exchange
assuming your ambient is cooler than in rad temp
which ofc it should be by the max ! as in keep room cool as poss with a/c or similar or a cooler in the sys b4 u get to the point where ambient is your lowest in loop temp
so what im after is MAX in rad time per size of rad. hence wehat is the rad that gives max in rad time as in slow flow or maximum water travel disrance per sq mm
so per squre inch/cm whatever you want to measure it in
what rad or combo will give max in rad time....
ofc within reasin cause u can say buy a rad of 50 cm x 50 cm and get the best 50 x 10 cm fans
but like i said with in reason so 4 x 120 or equivalent.
basically per size either a quad 4 x 120 or a 1 x 480 what gives best in rad time..
the doubles with a splitter seem good size v size but ...
what is the best design ?
The key thing to note is that there is always water in the radiator.
I'm going to have to borrow an infrared thermometer from work to show that this isnt quite true.the water in a loop will tend to reach an equal temperature through the whole loop - putting rads between each item doesn't actually give you any advantage other than looking like a spaghetti mess
