- 24 Jul 2020
Hi guys.
Around a week ago i received my first gaming PC after making the switch from Xbox.
I am happy with the PC,s performance for the time being but i am looking to change a couple of things my main question is are you able to buy some kind of cosmetic plate that covers the PCB on the Radeon 5700?
as the PCIE is at the rear of the PC the fan side is facing the floor and the PCB is visible and quite frankly looks bad.
I am going to do a small cosmetic overhaul on the PC and would like to use the 5700.
THANKS
THANKS
