What was a ten minute favour , has turned into a 12 hour nightmare, the thing is the card seems to work ok until i install the drivers , then it keeps crashing the pc, or it says its out of range or the the screen just stays black.ive tried 2 different versions of th ati drivers making sure i fully installed the other drivers, to rule things out ive done 3 clean installs and trying installing the drivers straight away but still it keeps screwing up. the m/b im insstalling the card on has onboard graphics but you cant disable them.Only when the monitor is plugged in to th o/b graphics slot, is when the option to see how much shared memory to use is available in the bios. Do you think its worth trying the omega drivers(if i can find them) or if any of you guys can help it would be much appreciated...... thankyou for even reading this
