- 12 Oct 2016
- Dublin, Ireland.
Check my sig, i have the 4gb Sapphire Nitro+.. ran GTA V well enough on pretty high settings and used less than 4gb of VRAM, about 3.5gb if i remember right.. BF1 Beta i had maxed out Ultra and i remember it using exactly 3.4gb of VRAM.. any issues then just lower AA.. Arma 3 uses less than 3.5gb VRAM while using x2 MSAA. This is all at 1080p.
The Sapphire card is fine as long as you dont wana max out every game you play.. but you're 5-6 hours a week gaming.. what you get out of spending too much on a system isnt gona be justified in my opinion.
The Nitro is a great card too, my temps never go over 60c, unless i run 3D Mark.
As for the memory, not much difference to be honest.. i have one of the fastest 480's in the benchmark threads by only overclocking the core to 1400.. on stock volts
You may get an upgrade itch down the line if you start playing more games more often anyway, makes sense right?
I came from a 7950 and im very happy with the performance, even though i'll be looking at baby Vega next year.
Im sure you're gona be more happier than me, going from a 7770 to a 480![]()
Quality post, thank you so much. I'll be ordering the card asap.
Thanks for the other replies... Even the ones who didn't really read the full post
So... I'll throw the RX 480 in with my FX 6300 for now and enjoy the upgrade.
Then buy a skylake bundle in January and sell on the old MB, CPU, GPU and RAM. Make a few quid back.
Thanks again.
