Looking to water cool my new Radeon vii when it comes but have no experience with water cooling other than buying pre filled kits.
Current setup:
Carbide 540 High Airflow ATX cube case
Corsair H115i cpu cooler pumping out the roof!
Radeon fury x pumping out the rear
2 280mm fans pumping in the front
I have room for a 280mm radiator in the front and going to keep the H115i.
Going to go with:
EK GPU block (Black)
EK-CoolStream CE 280 or 360
EK-XRES 140 Revo D5 RGB PWM Res/pump - is this enough if I choose to cool the CPU?
Fans TBD
What is a good solution for fuss/leak free connection pipe for an absolute beginner!?
Air flow would be:
280 fan blowing in from the rear
Corsair H115i blowing out the roof
EK cooler blowing in or out?
Thanks for any advice!
Current setup:
Going to go with:
Fans TBD
Air flow would be:
