Hi Guys,
I was wondering if there was anyone that could help with a (hopefully) easy to solve problem.
I took my radiator off to decorate and now I have put it back on it has a slight leak.
The nut will not screw completely onto the thread. I have tried to tighten the nut but it just starts to bend the pipe away from the wall now and does not seem to go any tighter.
Does anyone have any advice?
Pic below. I have highlighted where it is leaking from.
