Now its a bit colder at night the heating has come on.
Problem is that the rads downstais are fine but the ones upstairs arent coming on so its cold
i've tried bleeding the radiators and there doesnt appear to be any air locks in them as its only water coming out and no air. Pump is on full but nothing to do with that either.
Running a back boiler system.
Any plumbers with any smart ideas here that i could try??
Im going to now turn the heating off for 10 mins and then try and re-bleed all rads in the house - read a post via a google search that you cant bleed while rads are on? I would have thought a system under pressure would be better to force circulation??
cheers
EDIT: Oh dear, completely wrong section!! Mods, please move to GD when you get a chance!!
cheers
