MikeTimbers said:If the radiator is at the top of the case, I would have the fans between the radiator and the case pulling case air up and out.
I would have thought that you be getting much cooler air going through your rad this way...(from the outside in)Cob said:Is that the general consensus?
I currently have mine pushing air through the rad and into the case.
I have a 120.2 rad at the front of my dragon and the fans pull the air through the rad from the outside.Cob said:Is that the general consensus?
cavemanoc said:You always want the coolest air possible flowing through your radiator (the most critical components will be in your water loop!)
