Radio not working :(
8 Nov 2003
UK
Hello chaps.
I bought an Alpine 9847R ages ago but have never been able to get the radio working!
It didn't work in the 205 and it doesn't work in my Fiesta either. The arial cable is firmly plugged in and i've searched through the band for a station but it's not picking anything up, not even a weak signal!
What am I doing wrong? :(
Are you using an ISO adapter, or have you wired it in yourself?
I assume that the CD functions ok, and that it is just a radio reception that you can't get?
You can buy powered aerial adapters that fit between the aerial lead and the head unit input. These can make a difference, but even without on, you should be able to get a reasonable reception. Is it the same through AM as well?
That's correct yeah.
There are no problems with everything else it's just the radio which doesn't work, including AM.
It's plugged in using an ISO adapter yeah.
Are there any online shops that I can order one of those adapters?
Car audio direct are normally the best around for choice and price (no I'm not on commission!).
I need to pick one up myself as my radio reception is pants too!
Rotty said:
it's not a foreign import unit is it ?
No no, I bought it from caraudiosecurity.com (hope that's not a competitor - if so remove).
Thanks 'emailiscrap' (it is indeed) for the advice :)
Thanks but what does this mean:
The adaptor has a separate wire which must be attached to the electric aerial output of your new stereo.
I don't think mine has such a thing?
YOU WILL ALSO REQUIRE AERIAL ADAPTOR E115
:confused:
Going by the picture, that doesn't look like it would work. The slot that the arial goes into looks similar to a headphone jack.
Rem Ant lead or the blue wire can be used to send 12v to a device to switch it on when the car is started or the appropriate ignition position has been reached, this has nothing to do with radio reception unless you have an electric extendable antenna such as my MX i had to wire it up to make it pop up when the radio is turned on.
The more I think about this, the less confident I am that I've given the right advice.... :(
Can you literally not get anything, even if you manually tune into a strong local station? If this is the case and you've tried it in two cars, then I suspect the unit itself may be faulty, and therefore a signal booster may not do anything.
Depending on the car, (never fitted a hu in a ford before) you need to buy an aftermarket Antenna convertor, sometimes these don't fit right and will cause a poor signal.
Always the chance the HU is busted.
Nothing at all. It makes that white noise sound though. The original ford unit was working just fine.
Coming to think of it, in the 205 the arial would easily pull out if you just wiggled it so i'm now thinking the arial connector is too small for the hole...
