Rage - worth finishing?
29 Aug 2006
Hey. Noticed in my Steam library That Rage was installed on my desktop and remembered starting it on my lappy a few years ago.
I got to the dead hostpital and stopped there never bothering to go further.
So is it worth my while to finish?
I'm trying to go through my library and play or finish games but don't want to waste my time.
Cheers
Pick it up for bit and see what you think?
If you like fps, you'll probably carry on with it. I thought it was a decent title, though I regard it as more of a technical achievement than cutting edge game play - but consoles might have had something to do with that.
The visuals reminded me a little of HL2; from a distance they looked very good, but once up close, most looked poor.
I found it to be a great game, I ended up play it through about 3 times total before the DLC came out, and I'll likely replay it again with the DLC soon.
Grab the DLC and restart IMO, while the last 20% or so of the game is a bit flat and rather sudden ending theres a fairly decent game there and some great bits even if overall its a bit hit and miss.
I had it for 6 months before I played it, then once I started playing it wondered why I had not sooner, the Scorchers DLC was good to.
Cheers.
Might restart it cos I've forgotten about most of what I've played.
Too many games half finished.......
Used to be a time I religously finished every game I bought.
