Raid 0 Disappeared
17 Jun 2007
Just booted up my PC and one of my RAID 0 arrays has gone.
Disk management doesnt see it. Is there any other checks i can do before stripping the rig down and rebuilding.
Thanks
No using software I set it up using Win7 Disk management
I have 3 Raid0 and only 1 has disappeared.
I have had issues with the SATA ports before. And I assume that if I've got 1 dodgy connection then I wont be able to see either of the 2 drives
As i was stripping it down to investigate a SATA lead popped out completely. So replaced with another and the drive is back.
I need a better bigger case with better cable management
Ok its gone again..
So its not the cable.
How do I check whether its the sata ports.
Can I just move the cable to another port? Or will that confuse the RAID
