Id just like to know know if you can set up raid on any 2 HDD's - i mean i have 2 SATA drives both the same make and spec (7500RPM 80GB) but i think they are different models... is that a problem?
You can set it up using different drives(even different sizes) but Raid0 isn't the most reliable of storage methods to begin with and you are potentially adding extra complications so if you have any valuable data I'd suggest you either don't do it or back-up regularly. It should work fine although ideally you would have the same drives for both.
