I've got RAID 0 setup on two WD320gb disks and my system BSOD today and now it says 1 drive if an Offline Member in the RAID configurator. The Mobo is a ASUS P5Q. I've removed the system battery to reset all the options but still stays offline. I would consider the SATA drive faulty but the system recognises it fine and if I disconnect the other Online Member from the RAID set then the drive comes up as Online. Therefore, if I delete the RAID set and re-create the RAID 0 set does this just reconfigure the RAID set and not loose the data on the disks? Hence creating a new raid set with the original data and boot partitions?
The BIOS version is 1306 and there are 4 updates but non mention any updates to the Matrix Storage Manager. Your help and advice is much appreciated.
