I use a stripe size of 32KB, and a cluster size of 4KB, games run fine with this.
I suppose being a bit more "specific" about it, the larger the files within the game the larger the stripe size should be, ie a 32KB stripe is a good size for small files, like Windows XP.
Yeah, it depends on your average file sizes. Some games (like FlightSim2004) use lots of smaller files and I would select a smaller stripe - like 16KB, others use big DAT files and 64KB or even 128KB might be better. If you use a big stripe the worst you'll get is the performance of 1 disk as a lot of files won't get split, use a tiny stripe (like 2KB) and you reduce performance for all files much bigger than that as it will be broken up into lots of bits.
Personally I wouldn't use RAID anyway, but that's another question
16K really if you don't game and want a nippy windows.
32K for a mixture of both nippy wnidows and games.
64/128K for pure gaming speed - this is pointless though as how often do you actually utilise the HDU in games? Makes much more sense to go for 32K as this is a middle road for both.
I had used RAID for many years, both RAID0, 1 and 0+1. I just got fed up with it going wrong - plus (when I finally realised RAID0 was just too risky) having 2 additional drives running as mirrors is an inefficient method of keeping backup information (no compression). Can't say I miss it now I don't use RAID.
