RAID 1 or no point?
27 Oct 2009
West Sussex
Hi,
I've never been using RAID for my stuff, but since the HDDs are pretty cheap these days it would take quite a bit of my time spend on backups if I implemented RAID 1 for my stuff.
At the moment I have one F3 1TB and 128GB M4 SSD. The F3 is no more than 60% full and most of the stuff could be deleted anyway.
Would Raid 1 still give me better read/writes?
I know with that one, only if BOTH hdds would fail I would be pretty **** ;) but maybe this isn't for me?
I mainly need my software and pictures backed up but if I can protect all my data then great!
What would you suggest?
Thanks!
RAID 1 is a mirrored array where the same data is on both disks.
It offers no improvement to read and write speeds over a single disk but if one disk fails all the data is still present.
RAID 0 is where the data is split across 2 or more drives.
This gives increased read and write performance but if one drive fails all the data is lost.
RAID 1 is a redundancy solution not a back up solution. If your PC was stolen, destroyed in a fire etc. then your data is still gone.
A proper back up would have your data on an external disk stored away from the PC. Ideally in another building altogether.
