RAID 1: Retrospective
5 Mar 2003
Nottingham
Ahoy,
Just wondering if this is possible. I have a drive that I want to split into 3 partitions. When I've done all of my installs etc I want to install an identical drive as the first and set them up in RAID 1. The reason for this is I'm building a new PC and need the data off the one drive to be transferred to the new one.
So - is this possible and is it fairly easy?
Cheers!
Take an image of your drive and put that on, don't mess about with RAID, taking an image is a better way of doing it.
But that means I need to take the image every week or so to keep it up to date, where as raid does it automatically?
You should be able to do what you want. You'll need to setup the initial drive as being in the array and then hot-add the 2nd drive when everything is copied across. Your RAID chipset allowing you to do that is another matter though!
As others have said, don't rely on RAID as a backup, it's for redundancy, not backup (if you corrupt a file, it's corrupt on both drives in the mirror). I have an external HD and an online service (JungleDisk) that I use for important files. Most things though are already offsite (source code for work is on a remote SVN server, email is stored on a corp IMAP server etc. etc.), it's mostly things like family photos etc.
