Hi all,
Just wanted to clarify a couple of things regarding RAID if possible.
I know that you need 3 Drives for RAID-5, and that if one disk fails, then the server remains live. What happens when a disk dies? I was under the impression that you just unplugged the dead disk, and plugged in a new one and voila. Is this correct?
What happens when a disk dies in RAID-1? Does the server remain live? How is the array restored in the event of a failure?
Can a RAID 1 array be 'upgraded' to RAID 5 by adding an extra identical disk? Does identical disk mean one that's the same size, or just the same manufacturer, or even the same model number?
If you run out of space on a RAID-1 array, can a RAID-5 array be added to the same RAID controller?
Any help appreciated, many thanks.
