In my next PC I build I thought I definitely want some sort of backup, or at least a proper backup solution (I've decided I'll be getting 2 identical disks to do some sort of mirror).
I looked at RAID 1 - the one that if the disk fails then the PC will fall back on to the mirror and carry on working as normal.
I'm nowhere near buying this PC, I don't have nearly enough money & want to get a laptop first... but I've still decided I want RAID or something on it
Anyway, I had some questions about RAID 1.
So it makes a perfect mirror of your first disk onto an identical second disk, right? If one disk was to fail then the PC should automatically fall back on to the second disk... but that would only apply for hardware failure... ?
If I was to delete or corrupt some important system files would RAID replicate that damage onto the second disk and make them both non-bootable? Or is it possible only 'RAID backup' every month or so when you're sure the system is stable?
Craig.
Craig.
