Raid 10 with WD Reds & Greens
10 Aug 2010
Lincoln
I'm exploring some storage solutions. I'm basically looking for ~8tb of storage with some sort of redundancy.
I've mostly been favoring 4x 3TB Raid 5 but I already have 4x 2TB WD Green drives which were effectively going to waste (expect one which was going to be used as backup for a 2x Red Raid 1).
My latest idea is to go for a Raid 10, buy 4x WD Reds and utilizing the Green drives, effectively giving me free redundancy, and I'm not a massive fan of Raid 5.
My next question is probably obvious.. what issues am I likely to face here? I know its not ideal but at the same time, is this a REAL issue? Am I going to face issues with the green drives (actually two are WD Green and two are Spinpoint Green) spinning down when the reds arent, am I going to have issues with the greens taking time to spin up when the reds are already active? And I suppose read/write speeds will be limited to the slowest drives? (not really an issue as this is mostly for low demand media storage)
Any help much appreciated.
Cheers.
Use the greens as a backup of the reds.
Have the Reds in a Synology drive, then have the greens on a Windows machine, use 'Stablebit Drivepool' to create a virtual soft jbod of the greens, this will be 4x2tb = 8tb.
If one of the greens dies, you'll still have 75% of the data.
Robocopy between the reds to the greens. After replacing the broken green, robocopy will copy that lost 25% back to the drives.
And remember, RAID doesn't mean it's a backup. Just protects you against a disk failure, nothing else.
Anything more than RAID5 is super overkill for home use and just a waste of disks.
Yeh this makes a lot more sense and also solves a few other issues for me. It just shows the value of making a quick thread.
Cheers
I would however disgree with the RAID 5 comment for bigger disks. Home users would tend to have a lesser backup routine so a data loss is more likely - so having an array less likely to lose data is better.
IMO of course :)
