Raid 5 data recovery
22 Apr 2004
Greenwich, London
I have three hard drives that I believe were in raid5 config. How do I go about recovering the data on them?
Cheers.
Jimathy said:
first thing you'll need to know is the make/model of raid controller they were setup on i should think.
Yeah, you'll only be able to get the data back if you use the same controller as the original array. Not sure about all controllers but the ones I've used have the option to read the array config from the disks and put the array back together.
I think it was a dell perc 2. The hard drives themselves are old (3 x 7GB).
