I'm considering a raid 5 setup although I still don't know much about it or if it is the best solution.
From what I understand I will have 4 hard drives, all the same capacity, connected to a raid card. The space available will be 3 of the hard drives and the 4th one holds some sort of information that's capable of restoring the data on any of the other drives should one fail.
Is that about right?
Is there a better solution?
I recently had one of my 250gb drives fail which was very frustrating, although luckily it didn't have anything very important on it. Obviously to backup the 750gb+ of data I have to other drives so everything is duplicated seems an expensive and non-efficient way of doing it..
Any advice would be great
thanks
thanks
