Hey, I've just brought 3x 2Tb Samsung Spinpoint F4's ...
I've set them up using the motherboards onboard raid system (MSI P67A-GD53)
And I've started to transfer my data over (several terrabytes of it)
For the first part it seemed to be going well, the stuff transferred at about 30-35 MB/s
However now I'm getting about 7 MB/s ...
Also if I try and navigate through the drive during the copying the whole thing seems to lag up terribly.
So, my questions (appologies if they're self explanatory / simple)
1) Can I add extra drives to the RAID 5 array without losing all my data / having to back it up and rebuild
2) Is the fact my raid is beginning to get quite full the cause of it to slow down horribly ... Of the 4Tb of space I have about 1.1 Tb left
3) How will I know if one of my drives is failing / failed, as I've heard this can cause a significant loss in performance (Hopefully not this ... since the drives are only 3 days old)
4) Is there any way to skip the RAID config screen during boot - Since I've set the RAID up ... I don't really need to access that again
5) I'll edit this one later ... I can't remember waht it was now...
Thanks for any replies. Help is appreciated
.... £150
