RAID advice needed
18 Dec 2004
NE England
My mate had some problems recently with his computer - it's a Dell (Dimension 9150) with a RAID controller built into the motherboard, giving him the option of RAID 0 or RAID 1. It was initially set on RAID 0 when he received the computer, but after it corrupt a few days he decided to set it up on RAID 1. He says he's getting some decreased performance, but I don't know about RAID controllers.
Basically, does anyone know if RAID 1 decreases the performace of the computer significantly, such as startup speed?
-RaZ
RAID 1 will appear to be slower than RAID 0 simply due to the way the data is laid out on the disks.
With RAID 0 the data is split between each disk so each physical drive only supplies half the file - hence it arrives quicker.
RAID 1 on the other hand duplicates the data on both disks so to retrieve a file it comes off one or other, not both - hence is slower than RAID 0
In summary RAID 0 gives space and performance at the expense of reliability (one drive dies all data is lost). RAID 1 compromises space and performance for reliability (2 drives used but only space equivalent to one available).
Tell him to get rid of RAID and just use JBOD. RAID offers little to no performance increase over JBOD (Just a Bunch Of Disks) when used in home / gaming computer use and as previously stated, RAID 0 is less reliable.
Show your mate this article AnandTech did.
