RAID advice please
22 Nov 2003
Cardiff
Never dabbled in RAID before, so would like some advice please.
Can find plenty of advice on how to set up RAID0 from scratch, but not much clear info on how to do it as a 2nd drive once Windows 7 is installed.
Is it simply a case of going into disk management and combining the 2 drives, specifiy the type of raid you want, and then formatting them for Windows to pick up as one volume?
You are best to configure the raid on the bios of your raid controller.
I am assuming you want to use the controller on your motherboard?
You need to go into your bios and set the controller to RAID. Please note that this will probably make your operating system none bootable if it is on the same controller unless it was already in this mode to begin with.
Thanks for this, and yes I do want to use my motherboard's controller.
Hmm, are you saying I need to do a reinstall of my OS in that case?
Seems a bit of a potch :(
