RAID and Dual Booting
Permabanned
29 Dec 2006
Hey guys just need a bit of help with installing RAID Drivers.
Both my Hard Drives are formatted, i create a RAID 0 Config thats all fine.
Then i pop my XP disc in and it saids press F6 if you need to install a RAID driver, so i press F6 and insert my floppy disc with the driver on thats all fine. So XP installs fine.
Now i want to install 64bit VISTA on a second partion, is it a good idea to install the 64BIT RAID driver or might it cause a few conflits since i have already installed a 32bit RAID Driver?
Thanks.
The drivers are entirely separate and contained within each OS install. Therefore you need (as you've discovered) the 32 bit driver for XP and the 64 bit driver for Vista.
