Hi folks.....
I am building a new PC system for the 1st time and I am thinking of buying a couple of hard drives to put in a RAID configuration for performance reasons.
My plan is to use a parity RAID config. so that I can use many inexpensive disks (ie Maxtors x 4stripe +1parity) in a RAID 5 or RAID 0+1 config. I have read the Wikipedia article on RAID and I am none the wiser (I am a fool!!!). So what do I need to buy hard drive wise to have the benefits of the performance increase from striping but the reliabilty of parity from an extra single drive. I don't understand the difference between RAID 5 and RAID 0+1. Ideally I would like to buy 5 cheap 250-300GB drives (Maxtor DiMax10 SATAII) use 4 for striping and 1 for parity.... is this possible under a RAID config??? and can I rebuild a drive if one of the 5 go faulty?????
Sorry for rambling as I am a little tipsy !!!!!!..... Just on my mind thats all...
System being built ASUS M2NSLIMB ... 2x7900GTX.... 3800x2 AMD oc ..... etc....
Just that I think the HDD performance is a major bottleneck in general windows performance so I am hoping that 5 drives in some sort of RAID config will mean that I will have a superfast system. [subnote ... just that seems cheaper than paying out for the WD Raptors with 10K rpm speed rating.... I am not rich!!!!]
Hope u guys can help....
Jules
Jules
