I've built large numbers of PC's but until now never had the chance to include a raid array.
The plan is to include 2 x Western Digital WD2500AAKS Caviar SE 250GB 7200RPM SATAII/300 16MB in a raid to boost performance.
Now I'm assuming this will require using Raid 1 so the disks are mirrored for improved performance from split seeking. Or would it be better to go for Raid 0 for maximum performance, or does Raid 1 actually give better read performance (most important as far as I'm concerned).
Am I right in thinking that to setup the array you just turn Raid 1 on via the BIOS and then go about installing the OS as normal, or is there more to it?
Any feedback and advice would be gratefully received.
