I've been having regular failures with my RAID setup in both 0 and 1 mode, and I don't know if it is the RAID card or that the HDD's are slightly different that are causing the problem.
(I've used the SMART tool and the HDD's themselves seem to be error free. But if I run the tool with RAID, it crashes.)
My HDD's
WD2500JD (channel 0) 232.82GB
WD2500AAJS (channel 1) 232.88 GB
My RAID card:
A-390, PCI SATA RAID Card, 2 x int SATA, www.st-lab.com
Please help me. Should I buy a new RAID controller? Another HDD? Or should I just not bother with RAID for gaming? When it is working, the performance improvement is noticeable.
Latest error: (Some of the older errors seemed to not have been logged for some reason)
30-August-2011 21:34.11 Warning - SCSI Error - Aborted Command Error ocurred on Channel 1 Device on adapter 0. Channel 1 Device - Key 0b - ASC 00, ASCQ 00 - CDB 2a 00 02 b8 6a 7d 00 00 80 00 - INFO 00 00 00 00
30-August-2011 21:34.11 Warning - Member dropped Set 0 dropped Channel 1 Device on adapter 0 due to a SCSI error. SRB status was Error With Bus Status.
Warning error I get from testdisk on the second (mirrored) drive:
My HDD's
My RAID card:
Code:
Warning: can't get size for \\.\D:
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=10485…
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=10485…
file_pread(4,1,buffer,488279609(30393/… lseek err Invalid argument
file_pread(5,1,buffer,488398175(484521… lseek err Invalid argument
Hard disk list
Disk /dev/sda - 249 GB / 232 GiB - CHS 30393 255 63, sector size=512 - WDC WD2500JD-75HBB0
Disk /dev/sdb - 250 GB / 232 GiB - CHS 484521 16 63, sector size=512 - WDC WD25 00AAJS-00VTA0
Partition table type (auto): Intel
Disk /dev/sdb - 250 GB / 232 GiB - WDC WD25 00AAJS-00VTA0
Partition table type: Intel
Analyse Disk /dev/sdb - 250 GB / 232 GiB - CHS 484521 16 63
Current partition structure:
Partition sector doesn't have the endmark 0xAA55
Ask the user for vista mode
Allow partial last cylinder : No
search_vista_part: 0
search_part()
NTFS at 0/1/1
heads/cylinder 255 (NTFS) != 16 (HD)
filesystem size 40965687
sectors_per_cluster 8
mft_lcn 786432
mftmirr_lcn 2560355
clusters_per_mft_record -10
clusters_per_index_record 1
HPFS - NTFS 0 1 1 40640 9 63 40965687
NTFS, 20 GB / 19 GiB
NTFS at 40640/11/1
filesystem size 204796557
mft_lcn 786432
mftmirr_lcn 12799784
HPFS - NTFS 40640 11 1 243811 13 63 204796557 [Programmes]
NTFS, 104 GB / 97 GiB
NTFS at 243811/15/1
mft_lcn 786432
HPFS - NTFS 243811 15 1 446983 1 63 204796557 [Backup]
file_pread(5,8,buffer,488397176(484521… lseek err Invalid argument
file_pread(5,3,buffer,488397184(484521… lseek err Invalid argument
file_pread(5,3,buffer,488397231(484521… lseek err Invalid argument
file_pread(5,8,buffer,488397247(484521… lseek err Invalid argument
file_pread(5,11,buffer,488397294(48452… lseek err Invalid argument
get_geometry_from_list_part_aux head=16 nbr=1
get_geometry_from_list_part_aux head=8 nbr=1
get_geometry_from_list_part_aux head=32 nbr=1
get_geometry_from_list_part_aux head=64 nbr=1
get_geometry_from_list_part_aux head=128 nbr=1
get_geometry_from_list_part_aux head=240 nbr=1
get_geometry_from_list_part_aux head=255 nbr=6
Warning: the current number of heads per cylinder is 16 but the correct value may be 255.
Results
HPFS - NTFS 0 1 1 40640 15 63 40966065
HPFS - NTFS 40640 11 1 243811 15 63 204796683 [Programmes]
HPFS - NTFS 243811 15 1 446983 15 63 204797439 [Backup]
Invalid partition structure.
New options :
Dump : No
Cylinder boundary : Yes
Expert mode : No
