Raid Disk Driver problems ...
9 Sep 2010
Glasgow
Alright i've almost had it trying to get this to work, need help please! :p
Okay i have the asus p6x58d-e mobo, and i'm currently using the supplied disk to try and burn a raid driver install disk.... however, i enter the setup, select the 64bit version, and then the application constantly kindly reminds me that "no proper disk found..." however i have a cd-r in the disk drive?
Help?
Sorry if this is in the wrong place, wasn't sure where it should go.
-fedexer-
If you read page 4-15 of your manual you'll see that you can only use a floppy disk to make a driver disk.
However you'll probably find that your Windows install disk will already have Intel RAID drivers on it so you won't need a driver disk.
