raid error :-(
Permabanned
15 Aug 2006
Gainsborough, Lincs, UK
my new ram and thermalright cooler came today. the cooler has to have a new bracket to secure so i had to take my motherboard out...
Wen i plug it all back in (100% sure everything went back in same place (sata cables included) on boot up my raid array nvidia check thing said error....
and now i cant see it in my computer anymore :-(
any ideas people cus i got a lot of files in there i need and CANNOT loose. the hdd's havent died cus they were fine before i unplugged them and there only 2months old!
Cheers
Matt.
bios sees the hdd's no problem and the cables r 100% correct im sure of it... its confused me so much just cant think *** it is :-S
Please let someone hav the anser beg u guys!
Matt.
You sure you aint got the Cables round wrong way. (I aint 100% sure but if you have 1 HDD on Sata 1 and other on Sata 2 and set up Raid, and later swap cables round it will not boot).
Someone may be able to tell you.
How many times do I have to say this? This is what backups are for!
Is there anything showing in Disk Management or Device Manager?
nothing in disk managment or device manager...
ignore my sig its wrong i hav a 400gb sata which i boot off onto XP then 2x200GB sata's ina raid.... which r the problem :-(
Matt.
