RAID failure questions
Man of Honour
17 Feb 2003
Chelmsford
I have a RAID-5 setup in which one of the disks shows as an error. Therefore, as a result, the RAID has degraded.
I have removed the offending drive, and plugged this into a USB caddy on another system for testing.. I ran HD tune disk checking (full check) and it reported no errors?
How can this be?
Also, I can get the same Samsung 500Gb 16MB cache drives (these where just before the F1s), so will any 500GB drive be okay for a replacement.
RAID arrays can be a bit paranoid when it comes to marking drives as dead. Quite often the cause is the drive failing to respond quickly enough, possibly because it's been busy remapping a dodgy segment (hence why HDTune came back with no errors).
Before you go down the road of purchasing a replacement I'd run the Samsung diagnostics on the suspect drive, if a full scan with those comes back clean then you could stick the drive back into the array and hope it's just a glitch.
In theory any 500Gb drive can be used as a replacement although I'm not sure how the array will react if there is a slight size difference in the disks. Bigger is fine, it's what happens if the new drive is too small that I'm unclear about.
Ok, I replaced the drive that failed, and left the PC on for a few days whilst it rebuilt the array.. Everything works ok. However, the PC appears to be lagging and isn't as quick as it used to be. It's only aboiut 10% slower but this is more noticeable in Photoshop.
Any thoughts?
Are you certain it has finished rebuilding? Beyond this, what else have you changed and where does the 10% slower figure come from? Does the new drive differ from the old?
I'm quite surprised that you replaced the drive so quickly, Id have zero'd it and put it back in to see if it rebuilt happily. Depending on what system you're running the raid 5 on, you could now zero and add in the 'broken' drive. More capacity always good.
Something like: http://isomerica.net/archives/2007/07/12/growing-a-linux-software-raid-5-completely-online/
def finished rebuilding - I checked the RAID menu and everything shows as normal.
I couldn't get the same drive but replaced it with a drive of same spec (ie. speed, cache, capacity, latency etc) despite it being a different make.
