RAID help on a P%K(C)
Permabanned
25 Mar 2007
RAID help on a P5K(C)
Hi all,
I am having a bit of a headache trying to understand the instructions for installing RAID on my motherboard.
The instructions state:
"Install an internal SATA drive and an external SATA drive on your system" - why do I need to install an external SATA drive to configure RAID for my two drives?
The Asus P5KC only supports RAID on the JMicron controller, not the Intel one. Unfortunately one of the two JMicron ports is routed to the rear I/O panel for use with an external drive.
Therefore in short you can only do RAID on that board with one internal disk and one external one.
I don't believe it! :mad: I knew it was all to good to be true; my build was going fine until I hit this. I guess I am shopping for a RAID controller?
Can any readers in-the-know please spec me a RAID controller card? I am setting up a RAID0 set, SATA2, 2x320GB WD AAKS drives. I would like no bottlenecks on transfer rate.
The controller supports RAID but the mobo manufacturer has used one of the ports for eSATA so it's more a case of "you can" rather than a selling point.
Can't come up with a sensible reason though.
Well you need a PCI-E card, the PCI ones run on a 133MB/Sec bus so thats a bottleneck for 2x HDD Raid burst or if using many drives the actual transfer speeds.
I have a spare PCI-E x16 slot on the motherboard.
If either the PCIe 1x or the secondary 16x slots are free there are a few options. OCUK have a 2 port Adaptec 1x card for £30 or so or a four port 4x one for £75. There are other cards from Highpoint but you'd need to go elsewhere for them.
Yeah, there's plenty of bandwidth available - 250Mb/s from a 1x slot and 1Gb/s from a 4x one. A SATA drive on a 300Mb/s capable interface (SATAII is just a marketing name, not a standard) will burst up to about 260-270Mb/s but it's the sustained transfer rate which is more important, that's about 80Mb/s for a decent drive and 150Mb/s or so for a 2 disk RAID0 array so a 1x card is more than adequate.
Has anyone tried RAID on the Jmicron controller on the P5KC? You can buy cables that convert esata to sata but it would mean routing the cable from the back of the case into the case. Cables are £5 vs £35 for a RAID controller so wanted to know whether it was any good.
The JMicron controller isn't the greatest but it's perfectly adequate - there are plenty of folk running RAID0 on Gigabyte 965-DS3s which use the same controller.
